So im getting really pissed off since i superglued the second bearings on the sungear of the rear diff of my kraton 4s after 6-8 packs diffs still looks completly new no plastic residu to be found. And the bearing that was superglued i menaged to remove it and it left the superglue on the plastic so putting the bearing back in place is a lot more tight than before who was always floping arround. I decided to open my front dif and sure enough for some reason my second bearing too was loose maybe because i ran the truck for a few days without the center bearing holder because mine broke off. My sungear got a bit cheved up at that time but judged it was fine and cleaned and regreased everything. But today massive suprise more plastic residu from the sungear but the gear still looks "acceptable"-_-. So i did the same thing of what i did in the rear
I quess i will need a new sun gear just to be safe and but s bit of superglue on the second besring to hold it in place on the sungear. My theory is that the vibration made by the car is making the sungear to shake at a high frequancy becsuse the second besring is not suporting the sungear correctly
Also have put a new slipper rear hub because because there was too much play inside
Hope this stupid annoyance will be over
