Kraton Servo problem?
It was driving fine for a while and then it just died do esc probably?
Something is shot. Time to troubleshoot. Grab a different RX first, then grab a different ESC. You don't have to install anything, just unplug and plug in new electronics on the side one at a time.
Sounds like your servo is the problem. If it’s seized up inside and you try to turn the wheel, it could be drawing a lot of power causing your fan to slow down. Sometimes it might be drawing so much power that it causes the esc to just shut down.
Do you have different servo to plug in and test?
Yes i have a very small weak servo will that do?
