Shock broke, no damage?
The Bean
Weert, NL
  1. Notorious
My rear 6s shock came apart while jumping.
Somehow none of its parts are damaged. 🤔
It seems like that nut just came loose. Has this happened to any of you?
It just looks like a regular disassembled shock. Nothing special.
Should I lock tite the nut?
The nut in the shock should be a nylock.
No locktite needed, I have many 6s line cars and bashed them pretty hard and never had an issue with the shocks.
Shock came apart. The rod came out, but that was about it. The piston also came loos from the rod
Yea I have had the nut come loose on the shaft. I would just make sure it's tight when u put back together. And if u want put just a little dab of blue loctite wouldn't hurt
But I would wait a day to assemble after loctiteing the nut idk if the oil would do anything
Is stock oil rear 1k cst?
The manual says 1000cst, but it doesn't say front/rear. Is it 1000cst all around?
This is the only thing I can find in the manual. I'll assume 1k cst (80wt) all around is what is in there.
