Typhon Short vid describing how to raise body for dual 3s packs
Edough13
Bashing, Speed running and family!!
Hospitality Award
Northern California, USA
  1. BigRock 4x4
  2. Granite
  3. Limitless
  4. Kraton 6s
  5. Mojave
  6. Notorious
  7. Typhon 6s
  8. Vorteks
Just a short video describing what I did with the new v5 Typhon to be able to run dual 3s packs. Will need a Oc/Noto/K6s body mount post, and a Dremel or drill. Hope this helps those of us that run dual packs and have a Typhon ?
@Exc3l I can't answer that one bud as I don't have the 3s Typhon. I would assume it would be the same scenario as they are almost the same size. But I'm not sure if like the other 3s rigs the body mounts are adjustable and can just be raised?
From the looks of it you should be able to just use the longer Oc/Noto/K6s posts in place of the stock 3s posts
Yep you should be golden? the middle size is what I used on the v5? thanks I figured the pic worked for the season and shows my Arrma collection so far...
Of course the Typhon and Granite got some fresh decals since the pic?
