- Points
- 258
- The Motor City
- Infraction
- Kraton 8S
- Kraton 6s
- Kraton EXB
- Notorious
- Outcast 8s
- Outcast EXB
- Vendetta
so im sure everyone knows what an EXB Roller looks like when its fresh out of the box . so ill start this with a couple quick pictures of what i did and how the initial setup was like , then to the FULL rebuild , of every single screw , bearing , spacer , and piece of the truck .. FULL takedown cleaning and reassembly . fixed some issues along the way . i went so far into it because the further i took the rig apart , the more i found ether the factory missed , or just plain forgot . im going to try and post pictures and details about each in chronological order . this is going to be a very long post , but i will try and add to it often . this rebuild i drug out for 12 weeks while i was on medical leave from work.. so here it is my journey with the 5th scale Kraton EXB "Showtime"
chose the HobbyStar 56112 980Kv
i used some adhesive backed .125" foam to cover the servo/ receiver box bottom so its not a solid to solid surface . also keeps crap from getting underneath , and protects the chassis from scratches on the footprint .
dropped in a spare Spektrum receiver to mate with a Dx3s transmitter
went with the Hobbywing MAX5 ESC..
slapped on a 20 dollar set of Amazon fans and a crappy heatsink . . i know , i know ... noting too awesome yet .. but be patient . this is just how it started . gearing for my 1st run was 34/39
out for her 1st run !
wasnt happy with power delivery , so out came the center diff . ( still haven't gotten to the point where i started the full rebuild )
the nitty gritty of the trans/ center diff
" reassemble Stephany , reassemble "
packed her with 20 millie
being so thick i packed it full in stages as parts went in.
part # of the oil i used . Traxxas .... BOOOO
greased and ready to go back in
complete assembly
i used automotive high temp wheel bearing grease for mesh
accidently added the wrong pic . disregard the pic of my kid with his Rustler ... it wont delete .
complete assembly
