- Typhon 6s
- Thread starter
- #21
I need to up the temperature I think.what connectors are you using that look like a spoon?
The black wire is smoking sometimes when I try to sandwich the wires tighter together. I’m about to use a little bit of FLUX then solder.wires go down in that hole/cup, yes.
The biggest problem is fitting these plastic caps. ARRGHH!!Correct
I use 750-780F temps. I work fast, so those temps work for me. I use Lead based solder. Most of the experts who solder use these high temps.Dammit, I can’t find the soldering temperature I should set my Hakko at. These YT videos, they just start soldering and bloody hell they don’t mention the temp. I’m sitting here ready to go.
Work on your skills better. Soldering is intricate work. No over soldering is good. Solder only goes where it belongs, not outside of connectors. Heatshrink is always slid onto the wire jackets before you solder and kept away from the solder work. For obvious reasons. Shrink after the soldering is cooled down. There are tons of videos. Everyone appears to do it a little different. But if you watch enough of them, you will see a common denominator of what is correct and what works for you. The fundamentals are important. The rest is a learning curve. Some EC5 bullets snap into top and some bottom. Look closely at the bullet to see its proper insertion position. Find a video specific to your connector.If any solder gets on that connector where it’s not supposed to it will not work any I believe you are supposed to put the plastic cover on the wires first and then solder the connector on look up a video if you haven’t yet
Yep. The Leaded stuff. I think the brand name is Kester. I would have to get out of bed to check, but it’s so cold right now. When someone else gets up and turns the heater on, I’ll go check.Are you using leaded solder?
Some guys like to use wooden jigs with holes sized to various bullets sizes to reduce heat loss for that reason. Or you just end up with cold, dull solder joints.I failed miserably guys. That jig probably sucked all the heat away from the connector as I was trying to push the wire down into connector. The solder would solidify in a split second, not allowing me to push the wire in or set it in place. Anyway, I have to buy new brass bullets and EC5 connectors in order to try again. I won’t toss the batteries just yet. I need them to practice on. Next time around, I’m not going to use that jig. Instead, I will use the Hands Free clips suspended in mid-air.
