I am confusion help.
You’ll get it dude. Getting where you’re at isn’t easy. Getting faster than that is even harder. If it was easy everyone with a few bucks would be putting up those numbers. Glad the crash wasn’t that bad.had a pretty successful day out but no new pb unfortunately with the dual motor car.
At least I matched my previous 191mph pass twice today tho.
Road was really dirty and I almost had a very bad wreck on the third pass, car did a full 360 in the road when a tire blew but was able to almost keep it on the road.
It jumped the curb and busted a shock and ripped two motor wires.
80% throttle input on 8s-
90% throttle input:
95% throttle input but bad tire blowout
I seem to be stuck at the magical 191mph with this damn car, I know there is more in it tho
Should be a typo. Pretty sure all the SRD packs are 8g. They better be. I just ordered a couple of those for warm up passes. Couldn’t pass them up at $80 each.
There 10g.
My SRDs are 8AWG. I have two of the 6500 3S packs.There 10g.
I'll have to snap a photo. Mine has 10g on it.My SRDs are 8AWG. I have two of the 6500 3S packs.
Weird. I would expect nothing less than 8AWG on high performance lipos.I'll have to snap a photo. Mine has 10g on it.
Disregarde I thought it was the packs that I had. My 3s packs don't come in until today. But hopefully 8gWeird. I would expect nothing less than 8AWG on high performance lipos.
Set your KV value for about 80% of the actual KV value (1320 in your case) to account for load. Should get you in the ballpark.new PB yesterday. Finally broke the 100 MPH barrier. A couple questions though.
Running
X8S
CC 1650-1717
32T Pinion
34T spool
Limitless V1, otherwise stock
CNHL 6.2A 90c 3S in series
no cap pack.
on a 27T pinion I was able to ht 94 MPH so I was thinking that a 30T pinion would get me to 100 and to give me extra headroom, I bought a 32T pinion so I was a little disappointed that was only able to hit 103 MPH.
On the gearcalc app it calculates 124 mph @3.75V/cell 37,000 RPM with a 32T pinion. However, I only hit 103 mph and 33,500 rpm. I usually take into account voltage sag and assume I'll get about 91% of what the calculator states. Am I missing something? Voltage sag should be about 3.4V??? Or is this the "expected" speed for the above set up?
Your MMX8s data logs have all the answers you seek.new PB yesterday. Finally broke the 100 MPH barrier. A couple questions though.
Running
X8S
CC 1650-1717
32T Pinion
34T spool
no cap pack.
My V1 SRD 3S 8000s have 10AWGWell I'm more confused. Got an 8000mah otw regardless though
Running
X8S
CC 1650-1717
32T Pinion
34T spool
no cap pack.
YeahMy V1 SRD 3S 8000s have 10AWG
Without seeing the logs, it’ll be a bit of a challenge to see your issue.
My guess is it has more to do with the distance of your run. You’ll need to be on full throttle for a longer bit of time to reach max RPMs.
