Mike-NLD
Guys,
I was browsing the TPpower website.. And was wondering.. Are they useing a different way to meassure the motors?
For instance..
The TP4050 inrunner (6D) - normally that means.. Its a 40mm diameter, 50mm long can.. Right?
But the specs read 40mm diameter by 82mm long..
Do they meassure the rotor to come up with their second number?
Further specs:
KV: 2200
Max amps: 118
Max voltage: 27
Max watt: 3200
Max RPM: 60k
Poles: 4
This can an option to replace my stock 6s motor?
For instance..
Further specs:
KV: 2200
Max amps: 118
Max voltage: 27
Max watt: 3200
Max RPM: 60k
Poles: 4
