Grumpy Old Man RC
The stock Dboots Minokeiwa Mt 6S tires that come on the V3 Kraton are decent do it all tires
We drove the trucks on asphalt at first because the ground we so muddy and we didn’t want to mess the trucks up yet.
They performed OK. Stock servo could handle them fairly well but it could have been just a tad stronger for my tastes.
In the yard with really short grass they also did OK but just barely. Lots of spinning and sliding around and I didn’t care for that.
I put Proline Trenchers on mine and didn’t realize they came in two widths. I got the wide. Good and bad. Tons of traction and wheelies on demand, any speed below about 75% and you can raise the front wheels. The bad thing(s), the stock servo won’t even turn them sitting still and not a whole lot better when running even with the servo saver cranked as tight as I was comfortable with. Weight definitely affected run times. Lots quicker draining the batteries. Not real bad to balloon on 6s but did some. I could live with it.
I upgraded both of our servos to the Savox 1230MG with 400 or so in/lb torque. This servo is a beast. Not the quickest but strong as a bull even at 6v. If the run times were OK I would have kept the wide Trenchers on mine because they look soooo big and bad. I looked for the narrower Trenchers and could not find any. Seems to be quite popular.
Called a shop about 30 miles away but in the town where Sarah works and he did have a full set of dBoots Backflips so I got Sarah to go by after work and pick them up.
Very good tire so far after about 6 runs on 6s. ballooning not too bad and wheelies almost as good as the Trenchers. Run times probably doubled because the Backflips are about 1” narrower and a bunch lighter. The SA1230 really handles them.
I’m probably going to get the narrower Trenchers at some point but right now I’m tire poor.
Now to Sarah’s Kraton. She has Proline Badlands on it and she really likes them but they balloon like crazy on 6s. The front ones are bad enough but if even one rear tire gets off the ground, it causes suck a cluster truck it is down right scary. I can’t see how she hasn’t broken anything when this happens. I’ve watched tons of YT videos and have never seen anything like it.
She has decided to attempt to take the tires off the rims and tape the innards and see if that helps. I’m sure glad I saw her truck with the Badlands on it while on 6s before I bought a set for mine.
Well that is my very unscientific review of some tires.
I’m glad to see some better tires are going on the V4 Kraton. Maybe I need a set of those, hmmm, better not, yet.
