xgreenlepx
Will these hub extenders fit on the Typhon 3s? I saw someone post that they fit the Typhon 6s, but I don't know if they are compatible on the 3s as well.
Associated Hub Extenders
Thanks guys. The reason I’m looking for extended is because I installed rpm arms on the front, which are shorter than stock arms. I’m hoping the extenders can bring it back to the normal width.
Which RPM arms did you install?
Are you saying the new RPM Typhon arms are shorter than stock or did you buy the Granite/BRCC/Senton ones?
No Typhon arms anywhere at present :/Are there Typhon arms? I bought the granite/senton ones
They are in stock on TowerThe 3S arms are like hen's teeth.............. And what's the part number for those Red Cat extenders?
