Typhon/Silencer body help
San Diego, ca
  1. Typhon 6s
Question need an idea to mount this body to rear of typhon stock mounts, last option is to drill center hole threw towers. Please all ideas are considered. Picture of body lined up perfectly
If y’all have a pic of similar mounts send pick thx all
Problem bein?
The body posts are exactly in the bump of the body?
Id try to find a new spot for the body posts..
Just find a place on the rear shock tower where you can place them.. So that they line up to a flat part of the body.. Either more to the ouside or to the inside.. Drill two holes for each.. And remount..
If you take the largest of those.. Youll get somewhat more away from the shocktower..
You could also try.. Just fitting the stock spot.. With the ones you have on there.. I guess they are to wide to get sunk enough into te bumpnin the body.. It might be worth tryin to sand them down a little.. So that the sides become straight.. In stead of bein round.. That might make them fit in between te bump
I don't know what the sizes of these are..
https://www.arrma-rc.com/part/ARA320517
But.. If one of the will fit over the stock posts, while mounted in stock position.. Usein the outer holes.. You have the inner holes to put in one of these
https://www.arrma-rc.com/part/AR320453
Wich gets your new position just a tad more closer in.. So you get on the flat spot of the body..
