50TyphonDan50
Ok guys I'll keep this as short as I can. I bought a typhon 3s upon first drive I sat it down and took off and it turns out someone forgot to put that little screw where the pin goes. Within 30 feet a tire went 1 one way and the cars suspension arm dug into the ground tearing up all kinds of stuff. due to the lack of parts and wait times I did the whole Senton arms with extensions thing that worked for 2 regular rides in my yard. 0 bashing. Then when I was pulling up to myself to grab the car it went dead. Turns out somehow the servo and receiver are toast and it was totally dry outside. So I waited almost 2 weeks for new ones then installed them. After literally less than 5 minutes of just cruising around my back yard and popping wheelies the rear end is making a loud metal popping noise. Its definitely not the normal arrma sound that we are all so used to. It's the rear diff gears that have rounded off. This happened today. So I went and bought a big rock because I didn't want to wait that long with nothing to play with. Got 2 good passes up and down my side yard out of it ( no jumping or bashing) just getting the feel for it. Now the right rear axle shaft has broken. The pin sheared right through it. Currently I'm trying to make a Frankenstein out of the 2 but it's not going so well.i thought these things were tough as nails. I'm at a loss for words. We all know how much all this equipment costs with chargers and lipo batteries tires the trucks and buggies and everything else. How can I get at least 1 good vehicle out of these 2 piles of parts ? The axle shafts aren't the same I see. Are the rear diffs the same ? I could really use some help here. I have 12 sets of tires for my typhon and just bought some duratrax lockup my c2 2.8 mounted in 14 mm that I haven't even opened and wanted to try on the brcc. If I put the brcc arms on my typhon maybe I'll get a wider stance and make something happen? The brcc arms do look a little longer. Anyways. PLEASE HELP !!!! Any and all suggestions are greatly appreciated ! TYVMIA
