Appreciate the info. Unfortunately the stock pinion is a 5mm, and the motor I purchased has a 1/8th inch shaft.Hello and welcome to the forum.
If you upgraded from the brushed Senton to a 3s system the stock pinion is 20T. For the slipper clutch you can buy the full replacement from Jennysrc.com
https://jennysrc.com/collections/ar...ear-slipper-clutch-assembly-diff-57t-ar102668
As far as the slipper and spur gear, since you have that motor just leave it, add the motor plate and get some 1/8 pinions, I'd start with the 16-18 tooth.. see what motor temps and performance does, might be ok with a 20tThanks! The Mega comes w 17t 48dp pinion. Spur is 91t. Would you recommend any other pinions sizes?
I apologize, I should have been more specific. The stock pinion on the Senton 3s blx 3200kv motor is a 20t count. Below are the 1/8 bore (3.175mm) mod 0.8 pinions that will work with the mod 0.8 slipper clutch I posted.Appreciate the info. Unfortunately the stock pinion is a 5mm, and the motor I purchased has a 1/8th inch shaft.
