I‘ve been racing my V3 Talion at a local outdoor track since I picked it up in February 2018.
My skills improved and I realized I was at the limit of the “speed truggy” suspension setup. In February 2019 I installed Kraton shocks, shock towers, & axles/hubs. This dialed the suspension in to a point where I have been pretty competitive for an RTR.
The setup up to this point other than factory Arrma parts:
Kraton Towers & Shocks w Tekno rod ends
Shock Oils: FR 45wt RR 40wt
Shock pistons: FR 8x1.2 RR 8x1.3
Diff Oils: 7/10/4
JX servo: BLS-HV7146MG
SRX-482R (Sanwa clone receiver)
JConcepts Finnisher body
RPM wing mount
RPM Rear Skid
AR727410 droop screws
ARA330554 no-pop Turnbuckle balls
AON28CT01 Hot Racing FR Chassis Brace
AON21N02 Hot Racing Delrin Cap hub nut
Well the truck has taken some punishment and it’s time to replace the chassis plate so I figured this would be a good time to start a build log.
The diff clearance bulge in the chassis pan is gone from the front. ??
Diff Oils: 7/10/4
RPM wing mount
RPM Rear Skid
