I just added the Ti Balls and they are amazingSo far what I have done is the full Basherqueen set, M2C front and rear hinge pin kit, M2C front center brace, removed the sway bars, and removed the top cover on the battery tray.
What I am still wanting to do is the M2C speed chassis, and titanium adjustable links. Not sure if there is anything else I can do after that to drop weight.
What others bits did you order from scorched?Nice. I have all the titanium pieces I could get coming from Scorched.
Let me know what you think of the shafts. They look so thick I'm thinking they will have trouble interfering with the lower shock pins screws.Drive shafts, axles, shock standoffs, turnbuckles, and pillow balls.
Lots of people have been ditching their sway bars at my track because it's so bumpy. We got ruts and rocks. It needs some work.Never seen a 1/8 track rig without at least one sway bar. Either front or rear as needed. But just doing it to reduce weight is not an option IMHO. A minor weight reduction resulting in more body roll.
I also find that the Arrma 6s sway bars and their center retention setup is not all that. And are hard to dial in evenly left to right because of this. Sway is uneven left to right. NG.
For wide open field bashing, this is not so critical.
I use the HR alloy sway bar bracket at the Bulkhead. Keeps the center of the sway bar more flat. Helps better. The plastic stocker seems to flex when the sway bar is under load.
The stock tires and these tires came out the same on the scale. I am sure there are lighter tires but I also want to be able to go in all the terrain that I want. I'm not giving up function for weight savings. I'm trying to take off weight for less stress on the rest of the car.EXB Talion is heavy. And has a LWB chassis. Go with plastic F/R braces to save some more weight.
Any Truggy pin tires are the lightest in general. Less rotating weight/mass also.
If overall weight is really a concern, lose those heavy MT tires while you are at it.
