what part number is the set screw for pinion?
JAWS
Central Florida
  2. Talion
  3. Typhon 6s
  4. Voltage
I keep having trouble with my pinion coming loose on my Talion. I even put loktite and it still came off. it's looks like the threads may be messed up not letting me tighten all the way.
anyways, I go to buy another pinion at Tower and I see it comes with a 4x4mm Set Screw. I want to buy more, but can not find 4x4 anywhere on the Arrma website or Tower. closest I've seen is 4x3. what do you guys use? will 4x3 work?
Walter
  2. Granite
I would suggest you buy a new pinion and use the screw that comes with it. If the threads on the screw you have are messed up there is a good chance the threads in the pinion you have are in similar condition. It also gives you the chance to go up or down a few teeth on the pinion you are running if you so desire.
JAWS
Central Florida
  2. Talion
  3. Typhon 6s
  4. Voltage
yep just ordered one stock and one 14. I guess I was looking in the wrong area at tower. finally found the 4x4mm
