bicketybam
Back from vacation!
- New Milford, CT
- BigRock 4x4
- Granite
- Infraction
- Kraton 8S
- Kraton 6s
- Kraton 4s
- Mojave
- Notorious
- Talion
- Typhon 6s
Now that I have the new EXB, I'm trying to figure out what I should do with my almost fully upgraded V3 Kraton. The only things it's missing is alloy diff cups, and aluminum bulkheads. The rest is upgraded with a mixture of M2C, Voltage Hobbies and Hot Racing. I even have a Max6/Hobbystar 4092-1730kv combo in it. Here is what I have:
Voltage Hobbies
Shock towers
Steering rack
Wing mount holder
Upper arm mount
Lower suspension mounts (FF, FR, RF, RR)
M2C
Chassis
Rear shock tower brace
Shock caps and o-ring pistons
Front chassis brace
Hot Racing
Rear chassis brace
Aluminum steering blocks with pillow ball retainers.
Aluminum rear hubs
Arrma
V4 motor mount and diff mount
Copperhead 2 tires
Wheelie bar
EXB servo mount
RPM
All arms
Front bumper
Wing mount
I'm trying to limit the amount of space my trucks take up in my home and I certainly don't need two Kratons. What should I do? The reason I went for the EXB is primarily for the weight savings. I know it will not be as strong as this truck but it will be lighter and that's important to me. So transferring over all the parts really doesn't make sense to me. But I may want to keep some, especially the ones you can no longer get.
With weight as a factor, which parts would you put on the EXB? Let me hear your thoughts!
Voltage Hobbies
Shock towers
Steering rack
Wing mount holder
Upper arm mount
M2C
Chassis
Front chassis brace
Hot Racing
Rear chassis brace
Aluminum rear hubs
Arrma
Copperhead 2 tires
Wheelie bar
EXB servo mount
RPM
All arms
Front bumper
Wing mount
