Talion What was that sound?
HUGO .R
  1. Talion
Hi everibody the last time I was driving my talion I heard this sound:
What is it?
Thanks for your answer!!!
Sounds like your losing a diff. Time to tear it down and check it out.. could be a bearing yielding or could be some teeth missing, or both... no telling until you get onto it
I noticed a similar noise very briefly for the first time from my Typhon just yesterday. I've stripped it down completely but surprisingly can see no visible diff damage. There is a bit of play (about 0.5-0.7mm) on the pinion going to the crown wheel on the rear diff though. Gonna pick up some shims, try to catch it in the bud by shimming towards the crown wheel and and hopefully get a bit more life out of it.
You might be lucky and squeeze a little bit of life out of it but you're not going to get very much unfortunately just prepare and plan to change the pinion and Crown gear soon
