Thanks!This may sound like a bit of a stretch at the moment, but my advice would be to get a cheap beater rig for your beach trips. Something that you don't care about rust and wear & tear from the sand and salt. Fine beach sand will do a number on the bearings & gears. The salt is also pretty corrosive over time. If you do insist on taking the Vortex, be sure to clean it up as best you can with Fresh water & lubricant after every trip. Good luck
