GraniteGuy
As the title says, I took the motor apart to do the bearings and forgot to take note of which shims go where. Can anyone tell me? Its a Spektrum Firma 3660 3200kv motor found in the 3S cars.
I have not seen replacements for that part, but they might be available. Your motor might be OK to use if you put a bit of something to seal the cracked area to keep dirt and water out. But in my mind the stock motors aren't worth rebuilding: I replaced the stock motor in my Typhon 3s with a Surpass 3670/2850 motor that has more torque and runs cooler, all for around $40.Ouch... Just looked and the little black plastic piece that the wires go through is cracked. Do you know if I could buy just the piece, or do I have to buy a whole new motor?
