Granite Widened Granite BLX broken axle shaft.
GaGranite
Has anyone widened their Granite with Big Rock control arms and now have problems with broken axle shafts?
I had a front one break at the outer u-joint area on the first run with the widened arms. It may had nothing to do with the arms.
When I used to bash a big rock I had the same issue. Once the axles start popping apart at the joint they do it more regularly. I upgraded to metal axles (don’t remember the brand) and it quit but the metal ones sure are squeaky so you need to oil them where the two half’s slide together.
