Stanleybb50
- Senton 6s
Like the thread says, I need a little wider Offset. Not sure if these are called the hubs?
For example, here are the wider Offset Hubs for the Tekno ET48.3 that I got in order to run Proline 3.8" Wheels on my ET48.3.
TEKNO R/C TKR5071C Wheel Hubs 17mm 2mm Offset w/Pins EB48 (2) https://www.amazon.com/dp/B00F8OMDM6/ref=cm_sw_r_other_apa_RK4KxbH43NY6H
Does anything like this exist for the Arrma 1/8 vehicles? I just need like a millimeter or 2... As you can see from the pics. When I mount these wheels up, they rub in the outside of the hub carrier (I think that's what it's called) and frankly don't even allow the wheels to turn.
I tried my original thinner Tekno just as a test fit, but the pin on the Tekno is a little wider, so it doesn't seem like they will work... Maybe something for the Durango?
You can see the difference in the hex depth isn't that much, but it's just enough to rub bad and not allow the wheels to spin...
