Don mercier
Ive ordered typhone h20 wheels for my senton, im tired of buying tires. So im going with 1:8 rims and tires can i just put on typhone hexs?
Ive got duratrax mt on it now and they lasted 20 mins and balooned and ripped a hole in one, just throu away 1000$Stock is 14mm so you'll need to adapt to use 17mm or standard 1:8 wheels.
May also need to jack up the body with extended body mounts so the tires will fit and especially not rub when you're driving.
Oops 100$.so i just ordered the h20 1:8 tires and rims and hot racing 17mm hexIve got duratrax mt on it now and they lasted 20 mins and balooned and ripped a hole in one, just throu away 1000$
The h20 set is 117mm high and the duratrax are like 116mm high sothey wont be that bad, and i ordered a 15tooth pinionIve got duratrax mt on it now and they lasted 20 mins and balooned and ripped a hole in one, just throu away 1000$
Yes he will need the Typhon stub axles but why would he need the a arms? They have nothing to do with the wheels at all.Ok, you will also need the Typhon axles because the stubs are a different size than what is on the Senton. Do you know if the Senton arms the same length as the Typhon? If they aren’t then you will need those too.
I managed to find 17mm hex adaptors on hot racing for like 40$Yes he will need the Typhon stub axles but why would he need the a arms? They have nothing to do with the wheels at all.
I have a direct fit hex from HR that are a direct fit on senton and as long as you have the blx, the stub is the same, i just wasnt sure thays why i askedI thought the axles were longer and he would need the a arms to make them fit....unless he’s just swapping the stubs out I guess he wouldn’t then.
I have a set of Typhon hexes and driveshafts in my toolbox that I am eventually going to put on my Granite but I need the Typhon a arms. Or so I thought...it’s been a while since I looked into it but I thought that’s where it left off.
Both 10mmextensions and direct fit on sentonAre those adapters or just extensions?
No. As far as i can tell, you take the 14mm hex off and this is put on by it self. Its not an adaptor. Its a 10mm 17mm hex fitted for the blx 3s sentonOk, so the female hex is 14mm.
Ya i spent atleast 4 hrs serching and almost bought the same as youReally? I should have bought these then. I just bought the HR 12 to 17 x 10mm offset adapters.
The drive shafts are the same as the Senton and Granite, the stub axles, thee a arms and the turnbuckles are just different.I thought the axles were longer and he would need the a arms to make them fit....unless he’s just swapping the stubs out I guess he wouldn’t then.
Ya just the blx version are the same, i was going to order the a arms too, but with 10mm added on each side i think ill be good, i know the H20 typhone wheels have 0 off set so without the extenders on it would prob rub on the hub. Im hoping the stance will be wider than stockThe drive shafts are the same as the Senton and Granite, the stub axles, thee a arms and the turnbuckles are just different.
Um what? No the Mega 4x4 and the 3s BLX are the same.Ya just the blx version are the same, i was going to order the a arms too, but with 10mm added on each side i think ill be good, i know the H20 typhone wheels have 0 off set so without the extenders on it would prob rub on the hub. Im hoping the stance will be wider than stock
According to hor racing you need to change the stub on the axel i posted the reveiw aboveUm what? No the Mega 4x4 and the 3s BLX are the same.
Sorry I misread your post.According to hor racing you need to change the stub on the axel i posted the reveiw above
