Colinwarburton
- Infraction
- Typhon 6s
Hi everyone, wondering if a 5mm shaft will fit a 8mm mod1 pinion?
I think you misunderstood something because there is nothing press fit here. It's just all within acceptable tolerances.Its a temporary solution. Until the press fit wears out
We all know you can make a square fit into a hole. And perfectly.You guys are way too quick to say no. C'mon fellas, get gud!
Yes, it's definitely possible and it works. It will require a tiny bit of fabrication, but no special tools or machines will be needed beyond things you find in most of your typical home workshops and sheds.
What we need is an adapter. The problem is that, ideally, you'll want that adapter to be made of the same type of material the pinion is made from. Mod1 gears should be made from hardened steel if they're to be of any utility. Working hardened steel is a right pain in the buttox but we can try to keep it to a minimum. What I did was the following: I took a 12T 5mm pinion gear that I had no use for. It was the smallest gear I had which helps with the aforementioned issue. I affixed the pinion to my Spektrum 4074 motor, connected it to an ESC, battery and radio gear (only the Tx/Rx are needed). I revved up the throttle channel to a moderate speed with the trim adjustment, fired up the bench grinder and proceeded to remove the excess material from the pinion gear until I had something resembling the item below left over (proceed slowly and cool the gear down periodically with a dip in water to avoid annealing the hardened steel - if you see the steel changing color at all during the grinding process, quench it immediately and continue grinding...as I said, hardened steel is a PITA so, slow and steady wins the race). Once you get down into the 8.5mm OD, check with either a set of calipers or a micrometer as you remove material to avoid overshooting the goal. As you near the end, some test fitting with the actual pinion is a good idea as well.
I then bored out the hole for the grub screw to accomodate the straight through passage of the M5 grub of the 8mm pinion gear.
Here's the adapter sitting inside the pinion.
And here's the pinion mounted to the 5mm shaft of a CC 1717 motor. Having ground down the pinion while mounted to a spinning motor helped to ensure that the outside geometry would follow that of the motor shaft and the 8mm pinion spins perfectly concentric with no signs of a weeble or wobble.
There are surely other (and better) methods to fabricate one of these. If you're a machinist or have easy access to a machinist, I'm certain a little tube like this is something you/he can turn out while sleeping. Then just harden the steel as you normally would and take it to final size. This was just my way of obtaining what I needed utilizing common tools that most people have available (and if you don't, they're cheap to acquire used in the classifieds...every home should have a bench grinder).
Happy grinding
Is it worth the effort? Honestly, yes. Personally, I hate the M4 grub screws you find on most 5mm shafted gears. You can't tighten them down as hard, you basically have to replace them every 2 or 3 uses (sometimes less) and they just suck in general. I use M5 flat bottom Torx® grub screws in my 8mm pinions. I just outfitted all of my 8mm gears with them over a year ago and I have yet to replace a single grub screw (I don't put everything I have into it but I do torque them down pretty good, often skipping thread locker).We all know you can make a square fit into a hole. And perfectly.
But is it worth all the effort?
Just do it right with the right gear and matching I.D./O.D.'s from the start.
I know they make an adapter for larger pinions to a smaller shaft, but it is not recommended. I didn't like it at all, when I tried it.
For 5mm to 8mm, I would not use any adapter/ or sleeve. Why even chance a high power setup with even a slight Non-Centric shaft/gear alignment.
I wonder if I even understood this OP's question at all.
I hear ya. It's not my first pick either. I much prefer 8mm shafts (more robust, larger grub screws on the pinions, etc.). But this adapter solution solved an otherwise insurmountable problem for me: getting pinions larger than 34T for my 5mm shafted motors. There just aren't any to be had here in Europe and I'm not paying $21/gear from SAGA plus outrageous shipping charges, plus VAT, plus import & duty fees.I'm a purist. Maybe it's just my OCD.
Adapters make sense. Yes.
Just not my first pick. I would rather just source the correct pinion.
I have purchased a few "Cheap" AMZ pinions that came with adapters that make the pinion quasi universal to 2 size armatures shafts.
I just toss the adapters.
