- Granite Grom
- Infraction
- Kraton EXB
- Senton 3s
Just curios if the front rpm arms will fit the v5 and if it will are there any problems with using them
For bashing their arms are good for a speed run car or race car not so much.Are they as good as you think? If you need to try then try. I’m not a fan of any of the rpm stuff.
Believe it or not but I've been using the same Rpm front a arms since 2017. I think I replaced my rears in 2018.I prefer the RPM arms mostly at the rear. Seems like I broke the RPMs mostly at the front. V5 arms at the front seem better for me as well as the v4 front arms. But we all bash differently. Rpms at the front have too much flex between the whole upper and lower arm PB setup.
I think you do need the shorter V4 lower shock pins to be correct. The RPM arms are spec'ed as V4 arm replacements. U Can use the longer V5 lower shock pins. May stick out a bit longer, that's all.
