Big Rock With bigger tyres.
ChrisDown1
She looks and handles better with these wheels and tyres. ?
for that item: Hot Racing ATF117XT02 Aluminum Heavy Duty 17mm Hex Hubs 10mm Offset Arrma 1/10 4
since the big rock is 14mm hubs, do these just fit right on, or is another adapter of sorts needed?
I agree, I learned this the hard way. Even with blue Locktite mine still come loose every few runs. :rolleyes:
Yeah mine do as well... Doesn't matter what I do... If not those then the bolt that connects the barrel nut to the inside of the knuckle comes off...
You'll be in great shape with the 10mm extensions from Hot Racing. There used to be a longer process that required two new parts but now all we need is the Hot Racing ATF117XT02 and good to go (besides 17mm wheels / tires combo.)
