- Location
- Cleveland, OH
- BigRock 4x4
- Infraction
- Kraton 8S
- Kraton EXB
- Senton 3s
Girlfriend says I’m grounded
//-- Arrma
Arrma Kraton 8S EXB Roller (ARA5208)
//-- Castle Creations
Castle Creations XLX2 ESC (010-0167-00)
Castle Creations 2028-1100kv (060-0087-00)
Castle Creations 20XX series cooler (011-0019-00)
//-- HobbyStar
HS-6912 Servo (6912HV)
//-- Vitavon
Vitavon Bulkheads (BULKHEAD)
Vitavon F&R hubs (HUBS)
Vitavon Center Transmission Case (CTRTRANS)
Vitavon Diff Cases (DIFFCASE)
Vitavon Toe Links (TOELINK)
Vitavon Rear Upper Link (REARLINK)
//-- M2C
M2C Beefcake Kit (BEEF)
M2C Front Center Driveshaft (310923)
M2C Rear Center Driveshaft (310924)
M2C Beefcake Outdrives (310926B)
M2C XLX2 ESC Mount (3410)
M2C Motor Mount Slide (3253)
M2C 7mm front shock kit (3599)
M2C 7mm rear shock kit (3591)
//-- Hot-Racing
Hot-Racing Shock Caps (AFE156AX01)
Hot-Racing Wheel Nuts (red) (AFE10M02)
Hot-Racing Shock Collar Clamps (AFE156BX01)
//-- RPM
RPM Front Right Upper & Lower (81562)
RPM Front Left Upper & Lower (81522)
RPM Rear A-Arms (80812)
RPM Mud Guards (80642)
//-- Saga Custom RC
Saga Customs 31T (31T)
//-- Basherqueen
Basherqueen XLX2 Switch Mount (XLX2)
//-- ProLine
ProLine Masher X HP Belted 5.7in Tires (PRO1017610)
//-- SMC
SMC 9700mAh 4S Lipos (97399-4S1P)
//-- Misc
QS8 Connectors
//-- History
2/28: ProLine Masher X's
2/27: Shock assembly with hot-racing caps and 35wt fluid
2/26: Basherqueen xlx2 switch mount
2/24: M2C shock rods, cartridges, rod ends
2/23: Vitavon tie rods
2/17: Vitavon Diff Cups and 500k silicon
2/16: Vitavon parts arrive, installed bulkheads and many other parts
2/10: Soldered QS8's onto XLX2
2/7: Tear down differentials, remove gears, clean everything
2/5: M2C Chassis and a few other things
2/4: M2C Package arrives
2/1: Servo Installed
1/31: Started this build thread.
The "You're Grounded" Build
//-- Arrma
//-- HobbyStar
//-- Vitavon
//-- M2C
//-- Hot-Racing
//-- RPM
//-- Saga Custom RC
//-- Basherqueen
//-- ProLine
//-- SMC
//-- Misc
QS8 Connectors
//-- History
