Having a Granite 3s, Big Rock 3s and Kraton 6s, I decided to give the 1/8 Typhon 6s a go..
It came in and wow it's more the size of the Granite.....Kraton absolutely dwarfs it.
Where did they come up with the "1/8" scale designation for the Typhon?...
Kraton weighs a sizeable 10.7lbs...Typhon comes in at 7.5lbs...quite a difference.
I do like the build of it....quite a few parts are same/similar/borrowed from the Kraton (or other 6s platforms) it seems and it looks far more robust then the 3s line.
What I discovered is that 2x 3s hard-packs will fit but the body will no longer...seems to be a well known issue.
Ran it with 6s (without the body on it) and yikes.....wot is too much.....go's like a banshee....
Since I run 3s hard-packs on everything (personal preference as I don't feel comfy bashing hard with soft-case packs..)...looks like I either stick with 3s and change the gearing, drop in 4s or do both..
Curious to hear what/how other gearheads in the community are running their 6s Typhons..
