- Thread starter
- #21
The wheels are rubbing and need to be spaced out.
The spacers I bought doesn't fit my brcc, the shaft from brcc are to big.
Late reply, but one important difference I think is that wider arms adds not not just width, but also suspension travel (and higher ride height).Why are you adding wider arms, yet wider hexes are a concern? That doesn’t really make much sense to me. I would be much more concerned about the wider arms snapping. ??
Chopped down nail...BRILLIANT!I know you’ve already ordered the parts but I went down the standard Hot Racing 17mm adapter with extensions (+10mm) and the proline mx28s and so far it has made a world of difference to the truck. Traction roll is basically all gone now which although I don’t race it does make the truck feel much more enjoyable...
The HR adapters look great and have held upto the skate park abuse I’ve put it through so far... The only issue I had was spinning a wheel off after stupidly not using loctite but fortunately i only lost the pin... Nothing that a chopped down nail can’t fix...
If turning/wobbling is a concern then you should look into the HR steering bellcrank. I think it’s Too much money for a basher but may be worth it to you...
