Hey al I have a question which clutch you al use for arrma typhon 3s i have 26T pinion gear but always brakes the clutch or the screw losen to easy ty for eny help
As a new memeber try doing a Member Introduction post to introduce yourself, give more info on your issue. Might get more hits this way. But I think your issue is fairly common and on many other old threads already . Search around on AF.
I don't have any 4x4 Arrma's , all mine are 6s ones. Sorry.
Yeah Slipper Clutches can be hard to deal with. Most brands, not just with Arrma 4x4's.
Good luck.
And welcome to AF.
Welcome. Same rigs. I run the stock slipper clutch and plates. The latter versions of the 3s come with a rubber backing nut that prevents the clutch screw from coming loose. Also the typhon 3's come with a stock 15 tooth pinion. I can't even imagine running a 26 tooth. Must do about about 100 mph and overheat quickly?
Ye but now I have new shoks on and whana try speed run it on 26T have done whit my last broken battery that only loaded 10v max then i hade it on 120km/h and ye I use computer water cooling on him now trying that haha
Good luck.
And welcome to AF.
You will want to lower that typhon or youll be breaking cvd constantly. Had that issuse when using the 4s outcast shocks. Remove the preload tension, some tubing to limit shock extension and changed the 550 cst to 750.
