@jondilly1974 and everyone that has tried this. The video is under the spur pic. Skip to 4:50. He said I have to grind/shave the stub in the slipper hub down. Instead of that, can I drill a bigger hole in the plastic spur?
Do u mean it's going to grab the spur and it's just going to spin in my hand and rip it up? That's not a problem! I have a vice so I think I am good...The drill bit is guna grab. Either you guna break it or you guna rip your hand
I have a drill press in the garage. I have thought about it. Maybe it's time for me to get a bench grinder!A drill press would be best.
Its not my idea. Its rich duper bash'sHow did you come out with gear?
No, I haven't done anything yet.....I will prolly cut the stub off with a small hand saw I use for cutting plexiglass. Since the slipper hub fits in there perfectly in the spur it doesn't matter. the stub doesn't do anything.Were you able to grind the stubs down?
