southcakk843
Has anyone built an on road 3s street basher before the vendetta,infraction….???? I’m stuck on spur gear… I done went through all!!! Spur gear slipper arrma 3s has to offer n for some reason the slipper eliminator (diy) style traxxas spur seem to hold up …I jus lowered the gearing to a 13-14 tooth pinion…..only thing now is I want my car to be able drift wen needed n jus hook n book!!! But will the slippers plates hold up??? I kno the slipper eliminator is jus for speed runs only but um tired of my slipper keeps coming loose or that screw in the middle of the slipper breaks inside( done that many many time…so I thought bout that n just add lower differential fluid so I can get jus enough pump,pressure,power wateva u want to call it.. but to the rear but not much …yes I have metal diff’s n yes I know wat im doin jus lookn for inspiration and insight
