Can't seem to find anything search because "rod" is too short/common to use and I ended up with a ton of threads that were irrelevant. Was curious if there are rod ends that can replace the inside tierod ends on the 6S trucks. There are only 2 in the package when you buy AR330230, which I have 3 or 4 packages of and all of these ends are used up. Tired of spending $10 for 2 rod ends.
I tried some RPM ones mentioned before, but they were so soft that they just ripped during my first bash, same with the traxxas ones they would replace.
I suppose I could try traxxas's newest ones for the e-revo push rods... they are pretty beefy. Will have to use their steel balls though as they are smaller along with a washer/nut so they don't fall off if they do pop loose.
https://traxxas.com/products/parts/8647X
Thanks.
Thanks.
