Mr.Duke
Moderator
Community Leader
ArrmaForum Fan
- NC
- Infraction
- Limitless
- Kraton 6s
- Notorious
- Outcast 6s
- Talion
- Typhon 6s
New personal best this morning with the Outcast at 71.4mph
Hobbywing Max6 ESC
Hobbywing EZRun 4985SL 1650kv
Tekno 20 tooth pinion
PowerHobby 5200mah 75c 6s lipo
dBoots Backflip tires (sealed)
Diffs: 40/500/30
Stay tuned for 22 tooth pinion results late this week
Nice passes @Mr.Duke. What would you guess was your best time when still running the stock motor and esc, just for comparison.New personal best this morning with the Outcast at 71.4mph
Hobbywing Max6 ESC
Diffs: 40/500/30
Previous best was 67.3mph with the stock electronicsNice passes @Mr.Duke. What would you guess was your best time when still running the stock motor and esc, just for comparison.
Tires aren't taped or strapped just "sealed" meaning the holes on the inside of the rims are all taped off and not vented on the outside through the tread which is pretty common from what I've seenYou mentioned sealed tires. Are they taped or anything on the inside?
I would imagine you have to be near the limits of those tires!
Cant wait to see what it does on the bigger gear. Take some video!
-Liberty
I have 2 (business & personal) in case I break one, plus cheap replacement insurance on both in the event that something "unfortunate" happens.You're nuts @Mr.Duke and I don't mean doing 70mph odd with the Outcast (that's cool), ...I mean taping your phone to the Lipo battery and sending it off down the road at those speeds.
I'd get yourself a proper speed meter if you're enjoying seeing how fast it goes as if it does go wrong at least with a speed meter on board you're only going to lose $50-$100 rather than the $300-$500 odd for a decent smart phone.
Nope.Know of any speed device that also records accelerometer and mapping data?
Went out goofing off around the shop a little while ago and got one of the guys to take a couple videos. Suspension was set back to bashmode so the 2 speed runs I made were a little sketchy. 69.4mph was the best out of the 2
