Kraton A-Arm Screw fell somehow
ArrmaK8
Hello!
Ive been driving my kraton 8s when suddenly when I picked up my kraton. The arm were loose. And i thought i broke my arm somehow but after looking, I see no screw on the arm. Its the upper left arm. How can this happend?
Idk if you can see something or not 😂
Screws back out at times. They say you should give your rig a look see, and tighten all loose screws before every run. Also check the wheel nuts. Could have been loose from the factory. Not a bad idea to get a screw kit for your rig.
It is a good idea to check your vehicle after every run for loose parts, debris, etc. I have found many loose screws this way. Better than finding it was loose during a jump or speed run.
