pomplemus
Hi all!
While doing my usual inspection after a bash and getting ready for the next, one thing lead to another (dirt in bulkhead, found dead bearings, open diffs...) and now I have my front and rear diffs open for the first time.
My intention was just to replace the bearings, shim them up while I was in there, and replace the fluid. However, when taking them apart, I found the pins behind each sun gear were each broken into three pieces! I've found this so far on the front and rear, and haven't gotten into the center yet. I'm not super surprised (I may have gotten a bit overzealous during my past session saving a backflip and landed on power for a split second once or twice), but I do find it odd that it was driving just fine when I packed it up before the tear down.
Is it normal for the sun gear pins to break in a way that is not immediately apparent until you get in there?
Anyway, another issue I found was that the outdrives would not come cleanly out of the cup and bevel gear, I had to tap them out with a hammer. I figure this was because of deformation of the pin holes making the ends a bit bigger and no longer sliding through, due to the broken pins. Hopefully the cup and bevel holes weren't damaged by the removal, they seem fine to me.
Anyway, I have several spare diff components on the way, including some 2.25 mm drill blanks from McMaster to make my own (hopefully stronger?) pins.
I figure I should also replace all the outdrives as well due to the hole deformation- would M2C hardened outdrives be a good idea here to reduce slop and hopefully reduce the chances of this hole deformation happening again? I'm taking this as an opportunity to do a full overhaul after the 20 or so packs I've run through it so far, and I have plenty of new goodies on the way, including an M2C chassis and towers.
I welcome any other tips to toughen up my diffs while I'm at it! Shim, drill blank pins, new fluid, and rubber shielded bearings plus maybe the M2C outdrives if they are recommended is my plan.
Thanks!
Thanks!
