NewKratonuser0311
Hey guys what’s up looking for some info on the Typhon 6s v5 aluminum center differential. I’m upgrading from stock plastic center diff to aluminum center diff also going with the hot racing aluminum fine mesh motor mount. Once I installed the new motor mount and installed the aluminum center diff there is too much back and forth movement in the center diff. Also the front center drive shaft and rear center drive shaft aren’t as tight fitting as before. What’s the problem and what do I need to shim? Can anybody please explain what’s going on. Thanks..
