Notorious Another shim thread
Taspl
  1. BigRock 4x4
Gots my new notorious front/ rear diffs here, with shim kits mugen0206 and tekno1222
Whats the best setup for shims inside the diff to start with? Seem a few different options..
Remove all stock arrma shims and use the mugens on cross shafts/ sun gears
or leave stock shims, and add 2 mugens to satalite gears, and 1/2 to sun gears?
Whats are yall having luck with?
One each of the 5 x 18 under the big sun gear. You shouldn't need the 5 x 7 anymore cause I think Arrma started putting their own on the outdrives. As far as the smaller ones go, 3.5 x 12, That's a matter of preference. Some say one behind each of the small satellite gears (4), some say one per shaft (2). You need to dry fit the whole assembly and check for binding. Seems like a pain, but if you over shim it, you'll end up putting unnecessary strain on the gears. Too few, and you end up with slop.
Before you shim your diff, I would shim the input and crown gear first:
1 to 2 [8x12x0.2] shims (I use Kyosho's) behind the input gear (you'll probably have to heat up the input cup to break the set screw loctite)
And 2 to 3 [13x16x0.1] of your Tekno shims on the outside of the bearing of the crown gear side of the diff (I think V4+ already has one there from factory). If 3 is too tight, try taking 1 off and put it on the other side of the diff instead to bin off any lateral slop
What size shims fit best for the input gear? /crown gear
Those are the only shims i appear to be missing.
They're the ones I mentioned bro, Kyosho 96773 shims for the input gear, your Tekno TKR1222 shims for the crown
You just need to buy the Kyosho ones
Shhhiitttt, completely missed that part. My bad lol
Ordering now!
