Bigtim29
So I know traxxas chassis are plastic and seem to be pretty rigid. Would a 5-6mm thick plastic chassis for an arrma 6s rig with the same bracing they have be good? Would be lighter and more flexible.
I kinda want to try this now, seems like a good idea, half inch think is a bit much though IMO, but then again I wasn’t the one who made that chassis.I saw a guy on Talbot's videos that made a chassis out of 1/2" thick cutting board (HDPE). He was using it for the long jump competition. I think as long as it was braced with alloy chassis braces and a T2T brace of some sort to keep it from flexing a LOT, it would likely hold up for a while. Not sure how much lighter it would be over a M2C 7075 deck or Scorched Parts titanium deck.
If it's 1/2" thick solid deck, it might. lol!With a plastic chassis you would probably want honeycomb or some sort of molded or machined in bracing like on the 3s chassis. A flat plastic chassis might not hold up that great, especially on a 1/8th scale.
Something similar to this.
Haha if I had the materials and equipment I would have jumped right on it and tried to make my own chassis, that would be pretty cool. I thought the honey comb design was meant to reduce weight, is it a form of support?6m plastic will warp and flex, even with bracing. Keep in mid that you have 2-3 HP build into the platform. Now picture what 2 horses will do to your sheet of plastic
You have to go thicker or create a mold with build in support, honeycomb etc.
Feel free to try and prove us wrong, go with the cardboard body from the other thread and you have a cost effective solution definetly worth a try imho but doomed to fail in a spectacular manner.
