So that new alu servo arm is useless then? Wonder why did they recommend me that one with this new servo? they knew that my car was Arrma Granite and new servo is 25t. They knew I have Arrma stock servo saver with 23t, so that needed to replace.Most standard 25t servo arms won't fit because they are too long. You need the Arrma 25t servo saver or the Kimborough(?) alternative.
Only in New Zealand people do that kind of stuff.Because they are idiots?
Unfortunately Arrma can be a bit proprietary but a LHS shoukd know that.
At a pinch you can take the plastic 23t horn and force it into the 25t spline. Makes some people cringe but it works. I've done it and my mate did it to his Typhon and 20 packs later it's still fine. (And yeah I put grease in my diffs as well )
Most local shops don't know all of the specifics, just have a good general knowledge of RCs. If you want or need good accurate information about your Arrma truck always ask here first. A lot of people here that are more knowledgeable than your LHS.Really frustrating to passing ball back and forth about right spareparts. When they finally send those and parts arrive, they are the wrong ones. This canāt be their first broken Arrma servo case
LHS should know better their stuff and that shop is one of the biggest RC shops in Finland.
Don't forget the Europeans. Wish we had at least some upgrade parts available in here :|Only in New Zealand people do that kind of stuff.
Just kidding bud. Just sounded like the right thing to say at the moment.
Hi, can you recommend a ESC that has an adjustable BEC and works and with that new JX servo PDI-HV7232MG?Both JX servos are good servos. But the 32kg JX servo is also a HV servo that can be run at 8.4 volts and the only way you will get the full 32kg of power is to run the servo at 8.4volts. The problem is that the Granite stock ESC only has a 6v BEC and at 6v you will get 26kg of power and a 0.12 second transit speed. It's not bad at 6v, but is it worth the extra money to you? If it is, then get it. If you ever get a new ESC that has an adjustable BEC you can always use this servo with the bigger ESC. If not, the JX servo that they are gonna swap for free is an excellent servo and about twice as powerful as the stock Spektrum servo. It will definitely be great for your Granite.
Love your last line disclosureBecause they are idiots?
Much appreciated, Iāll check these out.Hobbywing Max10sct or get a Spektrum Firma 130 or Firma 150 from JennysRC. Firma 130 can run 4s, Firma 150 can run up to 6s. Hobbywing Max10sct can also run 4s.
A Firma 130 or even a 150 from JennysRC is cheaper than a Hobbywing Max10sct. I put a Spektrum Firma 150 from Jennys in my Big Rock and run it on 4s.Much appreciated, Iāll check these out.
Yes I know, but if I want to get full potential out that new JX Servo, that Granite stock Blx100 ESC canāt do it. Right?You don't need a new ESC, wth?
