Colinwarburton
- Infraction
- Typhon 6s
love running this beast on 8s!
all goes well at first, but then my esc cuts out, after the run i noticed my tire was dislocated from the ball joint, and the pinion gear shifted separted from the spur gear on the motor
i did a speed run because i wanted to see what my gps would record, i recorded 60 peak speed, its going quicker than 60 BUT Thats because i prob let off throttle at the beginning, need to figure out why.
looks like i need to change some parts or attempt again
your thoughts?
8S is wicked fast
specs
blx 2050 kv
max6 esc hobbywing
2x4 lipo batteries 50C 14.2 volts 5000mah 7.4kwh
24 pinion 50 spur
