Senton Arrma senton 3s badlands upgrade issue
Daniel K
I recently upgraded my stock senton tires to proline badlands 2.8. However the badlands are so wide they rub on the steering and camber links. Does anyone know where I can get 14mm hex extenders?
Which size wheel Hex hubs are you using with those Blandlands? The Senton is best with stocker SCT wheels.
You might just need the correct PL wheel hub adapater. To correct the Offset better for clearance. 14mm hubs in general are a hard find. An Arrma 4x4 thing. Most upgrade hubs available are 12mm or 17mm. Consider 17mm if upgrading. Like that from the 3s Typhon.
https://teams.prolineracing.com/images/6x30hex_chart.pdf
