Outcast Arrma Vorteks trade for outcast 6s (exb??)
Glitch
I’ve got a Vorteks with a lot of upgrades from some aluminum parts in the right place, pivot balls, mt tires steel spur and more. I may be doing a trade for a car advertised as “Outcast 6s” and was told yes to the question “is it an exb?” To me, it looks like a non exb 6s rig. Can anybody identify this model?
From the looks of it..
It's an older RTR version ,Not EXB.
It's missing the rear wing and wheelie bar and front bash bumper too.
Here's what a current EXB looks like >>
https://www.horizonhobby.com/produc...treme-bash-stunt-truck-rtr-black/ARA8710.html
Notice the Red shock towers ,center brace and chassis braces.
The chassis will have EXB on it too.
Show us what you've got in your Vortek
And we'll tell you if it's a good deal.
Okay, thanks!
Mods:
JX CLS6336HV Ecoboost Servo 35.6kg: https://a.co/d/bLdhI3Z
Surpass Hobby 125mm Monster Truck tires 12mm hex (preglued): https://a.aliexpress.com/_mM5yol4
Rcawd 12mm Extended Hexes: (🚨you need these to use the surpass hobby tires! They are the best solution for using these tires, with no extra or too little offset to mount them without rubbing. They are coming a little loose after running at the moment even with blue loctite. I will try red soon): https://a.co/d/9il0u7V
GLOBACT aluminum front steering block & caster block + rear hub: https://a.co/d/adrNZkN
GLOBACT aluminum pivot balls: https://a.co/d/9R1AcZq
FastEddy Bearing Kit: https://a.co/d/g0qnM38
Arrma Outcast 4s motor mount (1-2mm thicker than stock): https://jennysrc.com/products/copy-...uminum-motor-mount-set-heatsink-fan-ara4408v2
YSIDO blue aluminum 30mm motor fan (this thing is amazing):
https://a.aliexpress.com/_mNN5b1s
Powerhobby 57t mod 0.8 steel spur gear: https://www.powerhobby.com/phbarrma56.html
Arrma Outcast 4s 13t steel pinion gear:
https://jennysrc.com/collections/ou...-mod-safe-d5-ara4410v2?variant=40255726321718
3d printed motor brace from thingiverse- due to the way my motor is mounted I had to modify the file and shave down the print. If your motor is mounted the stock way it should work perfect: https://www.thingiverse.com/thing:4982263
I also have a 3d printed cylinder going between the motor and receiver box to keep it from thrusting forward in a crash.
Also currently using a Spektrum SLT3 off a Senton mega as the stock transmitter has a problem with the steering wheel. It stopped telling the servo to go back to center when I let go.
Yeah, sometimes the owner have multiple rigs and just happen to use a different box (or a similar box) to display the rig on/against..
So I never rely on just the box itself.
Study the rig itself ,is the best bet.
Wow, this is a mut of an RC.
V5 Chassis (Notorious, Typhon)
V1 to V4 Front and Rear Arms
V1 to V3 motor mount
V1 to V2 Battery Tray
V5 Rear Shock Tower
V1 to V2 Shock Stand Offs
V3 to v5 Bulkheads (Diff Case)
V2 to V4 motor
I love the button head screws on the bottom of the chassis!! 😄
