Typhon Battery charging issue
Jester194
Connecticut
  1. Talion EXB
  2. Typhon 6s
I have a lipo 6s battery and have been charging fine... Now when I try to charge it it says lower cell voltage and if I do it says voltage high....
I would check to make sure all the leads (main and balance) leads are fine and not broken. Does the charger show the voltages of each cell?
My voltage on esc programmer are 4.27 and then all 0 2 through 6 but total voltage is 24.57
So you’re saying cells 2-6 measure 0 volts? Sounds like there’s something wrong with your balance leads. Total voltage is probably measured through your main connector which is fine.
