Well it is already shipped so I am going to try it and see what happens. I was also thinking that I didnt set the ESC end points when I put it in. I am definatly frustrated and this is the best plan I had vs putting a castle system in it. I really don't want to spend that much on this car.It is just my opinion that the 2050 KV/6S motor will be going the wrong direction for you.
Sorry 2-3s batteriesHave you tried it on 4S or 6S yet?
LoL That is how I feel, like something is missing.I must be missing something, tell me again you’re set up. What is your spur gear? What is your pinion gear and the KV on the motor?
I didnt do anything, it ran forward connecting the wires to their same colorsWhen you installed the ESC you had to program it to run counterclockwise or did you switch the leads on the motor?
I bought the ESC from JRC on ebayI didnt do anything, it ran forward connecting the wires to their same colors
I just got home and I must have switched it to R on the throttle. I don’t remember doing it but I had to. Well time to reprogram the ESC but I can’t test as I don’t have another spur.When I replaced one of my 120 amp ESC‘s with the 150 amp ESC I remember having one that ran backwards when it was going forwards it was really in reverse. I’m hoping someone else has ran into this problem and will chime in.
Gear up 4teeth on the pinion if you have the room.3s 120c 6500mah batteries hardly any wind at all, road is smooth (a lot of locals speed run on this road)
