Minnox
What size motor will fit in the Vandetta without major modification? I will be running the Spectrum 6s ESC
I have a ezrun4268. Length 74mm + no problem. Diameter 40mm this motor is as big as you can go 1mm to spare.Do you mean largest? "Best" fitting motor depends on your goals. You can physically fit up to a 40mm diameter motor in there with no issues. And i know you can go as long as 74mm comfortably. Others may chime in, but I believe you can squeeze in a longer one as well.
just noticed with the 9th pinion the driveshaft rubbs against the motor. I didn't realize how bad until I tried putting on a center driveshaft support. Went up to 13th very,very close. My eyes are slowly falling. Old age!!I have a ezrun4268. Length 74mm + no problem. Diameter 40mm this motor is as big as you can go 1mm to spare.
I had that exact same setup this weekend and ran 72. Spectrum 150 amp 6s ESC on 6s with the stock motor, spool, and speed pinion. AVC was turned all the way down. Just ordered the 6s motor and a MOD1 36 tooth Pinion and a bunch of MOD1 pinion gears up to 26 tooth. If this dosent do something there will be a Vandetta for sale! LoLJust use the stock motor, 6s esc, and the 26t speed pinion. That’ll get you to 100mph easy. I did 102mph with that exact same setup.
Interesting. Something must be wrong then. You should be at the 72 speed right out of the box with speed pinion. Cuz like I said I did 102 with just a firma 150 esc and the speed pinion no problem.I had that exact same setup this weekend and ran 72. Spectrum 150 amp 6s ESC on 6s with the stock motor, spool, and speed pinion. AVC was turned all the way down. Just ordered the 6s motor and a MOD1 36 tooth Pinion and a bunch of MOD1 pinion gears up to 26 tooth. If this dosent do something there will be a Vandetta for sale! LoL
