Typhon Best servo, max amps, running 3 fans no underpowering
San Diego, ca
  1. Typhon 6s
Hey arrma dudes...I have a 1210 sg servo was working and still working but I installed mmx combo 2200 on 16t pinion, ok cool great speed
But now that I installed the 3 fans with a 3 wat splitter only option, the steering ain’t what it use to be. It use to be very quick with turns fading touch no knobs or nothing on controller. So I’m looking to get best of the best servo rather it’s $45- $200 just has more amps or maybe do I need to set servo to 7.4 amps I do have that b link system.
Either or I’d like input on spending money on servo or upping amps on 1210 servo.
Hears a few pick so far please way in thanks arrma
Dudes
To much being pulled on the bec. You might want to look at running fans on a separate 2s lipo but look at reefs servos. 500oz for around $120 nothing will slow that down lol
Dudes
I have a 2290 in my xmaxx
How do you that? Never heard of that one do you know Of link for that
You any good at soldering?
Wire them all up to a connector and plug them into a 2s. don't need a big one 2000mah will be perfect. Or an external bec would work as well. Just be careful they get hot.
External BEC will fry an ESC only if you connect it wrong.
Get a good BEC and that's it... If you up the voltage, things might get better or even worse.
Savoxes are pretty power hungry so changing the servo may help but it's not really a servo issue.
