Willyraceit
Is it worth it to put on the adapters when proline makes a good tire in the 14mm hex already.
Hello and Welcome!Is it worth it to put on the adapters when proline makes a good tire in the 14mm hex already.
Using adapters will give you more tire and rim options in the future.if you just want to run them prolines at 14mm then I suppose adapters are not needed.allways good to have a set around.becarefull going up to much on a tire size especially if your diffs don't ask for it .check your temps if you do .Is it worth it to put on the adapters when proline makes a good tire in the 14mm hex already.
There are a few reasons to change to 17mm, but if none of them apply to you, then there is no reason to change.Is it worth it to put on the adapters when proline makes a good tire in the 14mm hex already.
