AutoXmachine
- Points
- 123
- Panhandle FL
- Mojave EXB
- Senton 3s
- Typhon 6s
- Typhon 3s
- Voltage
Here is my Big Rock 540XL build with a lot more mods on the way. It’s a BEAST!
Rocking the Sledgehammers (Hoss)
And, of course, the 540XL with a 20t pinion with the Metal spur Kraton 4s clutch assembly, GPM fixed motor mount, Hobbywing C1 heatsink, and a Hobbywing SC8-RTR ESC.
Just a heads up, If you want to build one with the 540XL motor and an Arrma Safe-D5 Pinion Gear, you will need a 3mm motor spacer. The shaft is too long and the pinion will make contact with the motor mount backing plate.
