Has anyone used a hair dryer to unmount tires ?
I've seen it done but it takes a long time.Has anyone used a hair dryer to unmount tires ?
Acetone method ill try that one outI've seen it done but it takes a long time.
I have tried a few different ways.
Boiling them has never worked for me. I boiled the tire for an hour and it still wouldn't budge.
The one way that I have done it that has worked pretty well for me was I went to Menards bought a thing of acetone and a 5 gallon bucket with a lid, I dumped the acetone in the bucket until I had a good 2 inches in the bottom then I stuck some rocks in the bottom of the bucket so they were above the acetone. I put the tires in the bucket on top of the rocks then stuck the lid on the bucket and let them sit for a day. I opened the bucket the next day and the tires pretty much fell off the wheels.
I've been wanting to try this method out.
Remember to wear gloves so you don't get acetone on your hands.Acetone method ill try that one out
I've baked off many sets of tires. If you google it, you'll get the necessary recommendations. Never lost a wheel or tire with this methodHas anyone used a hair dryer to unmount tires ?
Will it workRemember to wear gloves so you don't get acetone on your hands.
Full day sitting in acetone on one side and 2 days gets all 4 tires or couple hrsRemember to wear gloves so you don't get acetone on your hands.
I have the Exabytes from my Typhon elevated over some acetone now in one of these. I stuck em in last night and will check in an hour to see if they've loosened. I will report back.I've seen it done but it takes a long time.
You don't want the tires in the acetone hence the reason for the rocks you are just using the fumes from the acetone.Will it work
Trying to sneak my girl Nail polish out the bathroom but she in the hallway and have to pass to get to garage and have no pockets damn it, it’s acetone or do you need commercial strength acetone?Remember to wear gloves so you don't get acetone on your hands.
Idk I've always used regular acetone, nail polish remover isn't straight acetone so it might take longer.Trying to sneak my girl Nail polish out the bathroom but she in the hallway and have to pass to get to garage and have no pockets damn it, it’s acetone or do you need commercial strength acetone?
You'll probably need about a quart of acetone at least depending on the size container you use. Costs about $8 at Home Depot. Also you may need to add more as the process goes on because the stuff evaporates quickly unless you have a tight fitting lid. Nail polish remover that is pure acetone will probably cost a little more marketed to women and in smaller packages but I'm only guessing.Trying to sneak my girl Nail polish out the bathroom but she in the hallway and have to pass to get to garage and have no pockets damn it, it’s acetone or do you need commercial strength acetone?
That's why I used the 5 gallon bucket the lid fits and seals up real nice, but you need 2 buckets for 1/8th scale tires.You'll probably need about a quart of acetone at least depending on the size container you use. Costs about $8 at Home Depot. Also you may need to add more as the process goes on because the stuff evaporates quickly unless you have a tight fitting lid. Nail polish remover that is pure acetone will probably cost a little more marketed to women and in smaller packages but I'm only guessing.
OkIdk I've always used regular acetone, nail polish remover isn't straight acetone so it might take longer.
Home Depot here I comIdk I've always used regular acetone, nail polish remover isn't straight acetone so it might take longer.
I hope the lid on the container I bought yesterday is tight enough. About to go out and check now but I'm betting a lot evaporated. Also instead of rocks I used some empty plastic tv dinner containers. If I have to try again I'll use some pieces of brick I have laying in the yard.That's why I used the 5 gallon bucket the lid fits and seals up real nice, but you need 2 buckets for 1/8th scale tires.
Don't use brick it soaks up the acetone.I hope the lid on the container I bought yesterday is tight enough. About to go out and check now but I'm betting a lot evaporated. Also instead of rocks I used some empty plastic tv dinner containers. If I have to try again I'll use some pieces of brick I have laying in the yard.
I'll have to find some rocks.Don't use brick it soaks up the acetone.
